  • 5 Replies
  • 2227 Views
Sc0ttb88
I have the seven day free cloud saving still but it has stopped working since 1 June - any ideas why? I have the Pro 2 cameras (2 in total).
Sc0ttb88
I had removed batteries and tried restarting base station but have just checked to see if armed and realised they are on a schedule! No idea how this was changed but I hope this will now sort it. Will report back and let you know. Thanks
5 REPLIES 5
DannyBearAgain
The 7days free cloud storage service is still working here.
Do you still see recordings in the library?
 If you live stream a camera using the app and can make a manual recording will it show up in the library?
Sungsoo2
Hi. My cameras stop recording since June 8 2023. I use free 7 day cloud. Anyone share the issue?
Sc0ttb88
Hi. The manual recording now works and shows in library but it doesn’t do it without hitting record. I’ve run a test with motion detection on each camera from the settings and it works fine but it just doesn’t record. Makes my cameras effectively useless. I’ll try u installing and reinstalling and see if that helps. Otherwise any suggestions? Thanks
Have you double-checked that the cameras are armed?
Also, have you tried removing/re-inserting the camera batteries, and also restarting the base?
Sc0ttb88
  • 5 Replies
  • 2228 Views
