Videos In Library Not Showing
- 2
1. I will get a notification in the app, but once I go to the library there’s no video
2. Sometimes there will be video, I’ll watch it but minutes later, they’re gone
3. Highlighted day is only TODAY. Although the dates scroll, I can’t select any othern day. So I don’t know if the videos from the past 7 days ares till there.
trastephenson,
To add to what jguerdat mentioned, There was a partial outage yesterday, this may have affected library recordings & live streaming. Does this issue still exist?
As a new subscriber, does this happen often?
There are lots of things broken with Arlo right now. They do appear to be working on them but I think you can expect to have lots of issues. For example this is a short list of stuff happening to me:
- Cameras go offline for hours at a time, no motion, no recording, no anything but they appear as online in the app
- Corrupted videos in library
- Corruption and lag in live view
- Missing audio from recordings
- Notifications delayed, taking 30+ seconds to be delivered
My cameras are plugged in but lots of other people using battery power have reported rapid battery drain issues. Sometimes it feels like there is more broken with Arlo then there is working correctly.
I have sent you a PM regarding this matter, please contact me at your earliest convenience.
Today I received my basic Arlo system (older generation cameras, no audio). When I look into the libray using a smartphone (Android) there are no videos in the library. But when I go to the libray using Firefox on a computer running Linux the videos are there. I thought I would be able to to access the library regardless of what I use (computer, smartphone, tablet).
Be sure the app doesn't have a filter set in the library - the funnel icon at the top should be empty, not filled in. If filled, click on it and reset and save the setting. That will show all videos from all cameras.
Have Arlo Pro with 3 standard cameras, all work as expected. But when I connect the Security Lights I do not get any video. The cameras show connected in the add, but I have no live view or recorded videos after receiving the notification.
Same problem. Missing video in library all devices. I receive email when motion detected, but library is empty.
Our Arlo library, which is free for 7 rolling days, has stopped saving the videos. I "need" this to maintain the property!!!
Will look to return this expensive failing system if not resolved in a timely manner. Suggestions welcome!!!
I was finally able to get the app working by downloading a new version. However, browser still not working. Safari + Chrome
For those of you who are having issues with this base being offline or not storing video I fixed my issue after realizing that the base is not comaptibile with 2.4GHXZ..if you have dual band router switch to 5.4GHZ and all will be well. My doorbell connected right away and all cameras.
- 2
