Try logging out and back in. Are you sure you have videos in April? If not, you won't see April offered.
I had the same problem with my videos not showing anything since March 31. Logging out and logging back in fixed the problem. All the videos for April 1 and 2 are there. It is aggraviating that this must be done, albeit a quick fix, aggravaiting none the less. These problems shouldn't be happening with this system.
Thanks. Logging out and back in sure did the trick....
