  • 4 Replies
  • 1473 Views
EJMBoston
Anyone know what that red usb icon is for? This just showed up and recording have stopped. Had this running for the last 2yrs and never seen that before nor has there ever been a usb devi c e
michaelkenward
Sensei Sensei
Sensei
Go to the bottom and look at STORAGE SETTINGS.
Red would usually signify NO. It does here.
You don't have local USB storage set up in the hub. It is just telling you that.
There has been an update in the Arlo system:
You’re in control with Arlo’s new Privacy Center? - Arlo Community
Just another user
Not sure this is the issue, but I am wondering if you have a subscription.
Also, what camera models do you have?
EJMBoston
So I have two hubs at the house (different models) the one in question has Pro2 cameras hooked up..actually they both have pro2 cameras. I'm under the impression if I upgrade to Pro3s I'll then need a subscription.
Correct - none of the newer cameras (starting with the Ultra in 2018) include the free 7-day cloud storage you have with your Pro 2s. Which is why I asked about both the subscription status and the camera models.
Are you able to make a manual recording when you livestream one of the cameras?
Have you tried restarting the base, and also removing/reinserting the batteries in the cameras?
  • 4 Replies
  • 1474 Views
