VMB4500 cannot connect to app. Went offline for a few weeks. Tried restarting and resetting.
  • 2 Replies
  • 954 Views
Feiwen
Hi All,
Hope to seek help on an issue.
My pro2 and the base station had been offline for a few weeks now.
Had tried almost everything i can find in this forum, including power reset, device reset etc.
As a last resort, I had removed the base station and cameras from the app, delete and install the app again.
However the app cannot detect the base station when I try to add it. The base station had been flashing amber light forever.
Anyone had the same experience?
Appreciate any advice.
Thank you.
Did you use the reset button until the LED flashes amber and let it reboot before trying again? It sounds like a hardware problem so use the Contact Support link at the bottom here.
Feiwen
I think other users in Singapore are facing the same issue as well. Found a separate thread on this. It seems that the ISP provider is the root cause.
  • 2 Replies
  • 955 Views
