VMB4000 base station can't be found. Turned on port numbers 80 and 443 for my ISP.
  • 1485 Views
JohnWMcQ
I am almost ready to give up but just can't believe it can't be done.  I've had my ISP turn on the port numbers 80 and 443 that Arlo told me I need open.  I was sent a screen shot my ISP showing they were open yet Arlo base still did not work.  I then tried buying my own router to have more control and was talked through how to set it for port-forwarding through port 80.  It is still not working.  Then finally Arlo mailed me a new base station and it is still not working.  What am I missing here?
What are the LED(s) on the base showing? Are you using a VPN? Have you tried a computer?
JohnWMcQ
The lights are green green amber.  I'm not currently using a VPN and I have tried doing it on my Mac Book Pro.
The amber Camera LED means the base needs to be claimed. Start by holding the reset button for >10 seconds, until the LEDs flash amber. Let the base reboot and try again.
  • 1486 Views
