Shadows set off camera
For some reason, one of my cameras (on my front porch) goes off every few seconds. I think it's the shadows moving? Maybe? How can I stop this without turning my camera off?
Yes, light changing like that can set off the PIR at times...
I would create a custom mode the same as what you are using and then edit it to lower the sense 1-2% at a time and test till it works better. ( then you can use that setting in the regular mode if wanted )
