VMB4000: Your Base Station could not be discovered
  • 13 Replies
  • 2080 Views
jdubeau
Hello, purchased a new Arlo Pro 2 off of Amazon in 2018. Brand new, just removed plastic.
Issue: Your Base Station could not be discovered.
Model#: VMB4000
OS/environment: android app & desktop my.arlo.com
3-LED Base Station: seems typical, starts as Power (Amber) and then goes to Power (Green), Internet (Green w/ intermittent flashing), Camera (Amber)
Network: VMB4000 is confirmed in my network map (using Linksys router)
Based on other help articles, I have attempted a few things already:
- Following in-app & arlo website's troubleshooting guide (i.e., plugging in ethernet port before power, doing the network scan in the app finds nothing)
- Multiple 10+ Factory resets (waiting for amber lights)
- Switching cables and ports on router with a known good cable/connection
- Forcing Phone & Desktop onto 2.4ghz wifi (including temp disabling 5ghz band altogether)
- Closing Router firewalls and Windows Firewall
Should the Base Station also have a Wi-Fi connection showing in my network map maybe?
If anyone has any ideas, I would greatly appreciate it! Thank you!
13 REPLIES 13
It will - but that is locked down, and only used by the cameras.  So you cannot join it.
Can you connect the PC to the router with ethernet?
If you use a VPN, then disable it before onboarding.
jdubeau
Thank you, StephenB.
Yes, my default PC connection is via ethernet. I tried that way at first, and also tried switching to wi-fi, and finally to 2.4ghz only wi-fi (disabled 5ghz in router tools).
No VPN is enabled.
Edit: in case helpful, I also see NTG-VMB_(string of numbers) in my Wi-Fi list. I'm guessing that's the aforementioned camera Wi-Fi!
Mine show ARLO_VMB_xxxx, but they are newer bases (and running current firmware).  Since yours is old, it likely hasn't updated to current firmware yet.
Did you try the paperclip reset?
Normally your symptoms are because someone else has the base station in their account.  Did you purchase new in 2018?  Or was this refurbished (perhaps from the Amazon store)?
jdubeau
Thanks again.
Is there some way to force the firmware update possibly? That feels like it might be the issue.
I have tried the paperclip factory reset over 10 times, holding it down long enough to get the three amber lights flashing. For good measure, I also tried a couple times holding the reset down for close to a minute or various lengths of time.
I triple checked my Amazon receipt and it confirms New condition - not refurbished.
BrookeN
The firmware is unable to be pushed to the VMB4000. An update will be coming soon, however I do to have an exact ETA. I will provide more information to the community as soon as possible.
jdubeau
Thank you, BrookeN. Glad to hear.
BrookeN
Can you check to see if you are able to update the firmware?
jdubeau
I can't seem to update the firmware. Is there a way to force the update before it's listed as a device on my.arlo.com? It's still unable to locate the base station, so I'm not sure where to begin.
I did verify that the base station is in my network still. It's still powered, and the lights go green (except for 3rd camera indicator which stays amber). I tried to factory reset, and unplugged and replugged all the things, but no luck.
BrookeN
Were you able to update to the newest firmware?
RachelWC
I am having the same issue and have tried everything suggested for troubleshooting multiple times.
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing.
jdubeau
@BrookeN Since there are no devices connected, I am unable to select anything within the support center on the mobile app, except the "Subscription" button and an add for a free trial of Arlo Secure lol
BrookeN
@jdubeau I created a ticket for support to reach out to you. They will reach out as soon as possible.
  • 13 Replies
  • 2081 Views
