  • 2 Replies
  • 845 Views
Dexor
Bought the VMA1000 mount @ Amazon and in about a year it got rusted at the screw where the camera attach to the mount. I live far from any ocean or salt in the air. The mount is poor quality and doesn't stand outdoor weather
JessicaP
Hi @Dexor,
I will suggest having our support team helping you with this if you had it for about a year. I have sent you a private message so I can help create a case for you.
paddos
Unfortunately not a quality issue. It's a design issue. Needs to be stainless versus current design. All my outside mounts have rusted. Using silicon grease to slow rusting process. Was told by JamesC engr was working on a fix 6 months ago ... still waiting.
  • 2 Replies
  • 846 Views
