Using Wasserstein solar panel to charge my Pro 2 but seeing red charging icon? What does it mean?
I am using Wasserstein solars panel for charging my Arlo Pro 2 cameras. They seem to work fine.
I have occasionally noticed the red charging icon below. What does it mean?
Note: I live in Arizona, and it's only 102 degrees today. (most days in summer it can be 110+) Is this anything to be concerned about?
While it could be an issue with the use of a 3rd party charger, I'd guess it's a heat issue. Is the camera in direct sunlight? That would tend to heat the camera more than in the shade and then there's the issue of an AC-powered camera always running so generating more heat itself than a battery-operated one would.
Solar panels produce less power when hot, so that might also be a factor.
@GregyHowell wrote:
I have the same red charging icon on my cameras.
The red color doesn't mean there's a problem.
@JamesC wrote:
The red icon with the lightning bolt is an indication that a charger is connected but no actual charging is taking place. In these cases, it means your solar panel is connected and functioning correctly but it's not charging the camera (likely because it's not in direct sunlight or it's night time). We're working on getting our documentation update to reflect this new icon behavior.
FWIW, I think this UI change is confusing - particularly when a solar panel is used. Also, I don't think red is a good color for something that is a normal status.
