Using 12v battery for Arlo base station?
Anyone running the base station on 12v battery instead of the wall charger?
Batter is charged with solarpanels and voltage can go as high as 14.3v.
I don’t have a battery on my base station Vmb4000 but can’t see why it could not work.
Can I ask for further details as to what you need to know.
Do you need to know how long the battery will last. Is your location without power so your trying to operate the system relying on the solar panel to keep it operating continuously.
Have you considered the internet router power also.
