Upgrading Arlo system - Where do I find instructions?
I have had Arlo for years and the Pro cameras are not working like they used to so I purchased the Arlo Pro 2 to replace the non working cameras. I can not find any instructions on how to upgrade the system. Do I have to delete the existing cameras and base station and start over? I am paying yearly for 10 cameras at the present time, how is this effected? Where can I find instructions?
There are no special instructions to upgrade...
No need to start over or change out base unless you want to...
If you are limited to a number of cameras, just remove ( remove device ) them and then sync in the new cameras that replace same
If you have two bases, set up 5 cameras on each for free and then share ( grant access ) the second unit to the first.
