Just installed all good then got message to upgrade the base did that and couldnt find device
So I removed the base etc
Have turned off everything to start again I get the two green lights but the app can mit find the device now
Hellllllppppppp so frustrating
Save time and remove everything from Settings, My Devices. Hold the base reset button until the LEDs flash amber. Claim the base again and then sync cameras. Update firmware if prompted as you go.
