Trying to update my new Arlo Pro 2 camera. Clicked on Update on the app screen. Few minutes later it states "Upgrade Failed. Camera Rejected. Upgrade Required."
How do I resolve this?
Guru,
Thanks for your quick reply. Will try your suggestion. Thanks again.
Reboot he base and reinsert the camera battery. Try again. If still no good, remove the camera from Settings, My Devices and resync.
Guru,
