Unwanted motion detection events at 80 sensitivity
I have had Arlo cameras for a few years now. 1 particular camera is mounted on a outdoor shower and shoots straight down a 25 ft walkway from my front door to the road. I have landscaping and a fence to the right of the walkway about 7 ft to the right. My issue is the sensitivity. At 80 on the previous arlow card driving by at the end of the walkway were never triggered. Should lowering the sensitivity? I’ve deopped it down to 40. Hopefully this will work without having to take this back.
Any ideas??? Thanks
Mpowered,
Lowering the sensitivity is a good place to start if you're experiencing unwanted triggers. You might also consider changing the angle of the camera placement so that areas where unwanted motion is occuring is out of the cameras field of view.
						Arlo Mobile App628
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
