USB Drive with Arlo Pro and Pro 2
I'm looking to get a USB Drive for use with a 5 camera Arlo Pro 2 setup. I understand that USB drives up to 1TB (FAT2) are supported, but are there other specs I should consider? Is USB 3.0 supported?
What specifc drives have folks had success using with the Arlo base?
Thanks,
Steve
USB 3 i snot supported since the data rate isn't at that speed. I wouldn't use a hard drive - just use a thumb drive. It's much easier to remove and reinsert with almost no space needed. I used a hard drive for a while but just use a 16GB thumb drive now. If you do lots of videos and want them for longer times, just use larger capacities.
Agree...running a 10-32 Gb speed stick will give you videos than you need.
btw, it's 2 Tb max in the specs, and format is fat32
