  • 11 Replies
  • 12760 Views
  • 18 Likes
  • 11 In Conversation
tricwhyte
I've owned 2 base stations and 4 Pro 2 cameras for 2 locations (one home + one condo) for 7 years (home) and 5 years (condo) now. Under the old UI I was able to maintain 2 locations and easily disarm them separately without the need of a subscription. In addition, I had 7 days of cloud storage for no charge.
Now, I was planning on buying 2 additional cameras for my condo to put into a common garage and give our neighbors access to those cameras. In prep for this purchase I was forced to upgrade to the new UI and now all cameras were put into one location. In addition, after doing research I'm being told I need to purchase not one but two subscriptions (one for each location).
Am I actually stuck going from no monthly payment to ~$20/month just because I upgraded the UI? Please confirm because if this is the case then I'm more than happy to move to Eufy cameras simply out of principle.
11 REPLIES 11
The UI migration isn't the trigger.  Pro 2 cameras were sold with 7 days of free cloud storage, as long as you had 5 or fewer unsubscribed cameras in the account.  Arlo still honors that, but stopped offering free cloud storage on new models starting with the Ultra back in 2018.  All currently sold cameras require a subscription for cloud storage.
  • So if you add the new cameras to your account you will need to get a subscription.
  • But if you stay with the new UI but don't add any more cameras, you shouldn't need to get one.
Options are to
(1)  purchase a VMB4540 or VMB5000 smarthub with the direct access to local storage instead of the subscription.  This won't work with the Essential Gen 2 cameras at the moment because Arlo hasn't yet added smarthub support to the Gen 2 cameras. So you'd either need to exchange them or wait to install them until the feature is added.
(2) Return the new cameras you purchased and instead buy two used Pro 2 cameras.  Then create a second account for the condo, and share the cameras with the your home account.  Since both accounts would be under the 5 camera limit, you would still get free 7-day cloud storage.
(3) Return the cameras and get something else ifor the garage nstead.  You can of course continue to use the Pro 2 cameras.
That is just because the two bases were controlled separately.  Functionality would be the same if both bases were at one location.
With the new UI you can set up a second location for the Condo within the same account.  If you were to do that, you would be still able to change the modes in the two locations independently.  This does not require a subscription - but going over the 5 camera threshold will.
Note Arlo doesn't provide a mechanism to switch back to the old UI.  Plus they are planning to drop that UI as soon as they feel they can.
Razza_NZ
Yesterday I made the mistake of upgrading to the new app.
With multiple cameras in 4 separate locations, I now have to pay 4 times as much each month.
For this reason, I'm now evaluating other camera solutions.
Edinburgh_lad1
sorry @StephenB but I'm not getting this: how is it that before the upgrade the OP could access their cameras but now they can't, and you saying that the issue wasn't caused by updating.
Please clarify.
Please clarify.
Are you asking this on the wrong discussion thread?
@tricwhyte never said the existing cameras couldn't be accessed. The issue is simply the need for a subscription -  which is triggered adding two new cameras to the system - NOT the app upgrade.  It's just because all currently sold cameras need a subscription for cloud storage.  Plus the new cameras bring the OP over the 5 camera limit for free storage.
FWIW, OP would only need one subscription, not two.
Therefore OP will either need a subscription or use local storage on the new cameras.  If @tricwhyte goes with local storage, the best option is to create a separate account for the garage cameras, and to put existing pro 2 cameras in garage.
astrench
DO NOT UPGRADE TO THE NEW ARLO APP. The new version eliminates the ability to manage two locations. ARLO may make it seem like an upgrade, but it’s not. Now, ARLO is asking me to pay $223.99 for an additional location service to access the same features I had with the old app.
Eyeguypec
I have 23 devices that are in 3 different locations, all covered by 1 service plan. Then the update happened and suddenly I have to purchase 2 extra service plans to accomplish the same thing! Feels like extortion……..now I am looking for a new provider…….
ittroll
Luminary
Luminary
Presumably no warning was given during the upgrade. How can that be legal?
Arlo Wire-Free, Pro, Pro 2, Go, Q, Q Plus, Baby - You will continue to have access to free 7-day storage even if they enter the EOL stage. For local storage, the VMB4540 supports recording to USB with direct access from the app.
Lsetzler
I have Arlo cameras at two locations. The upgrade sounded good, did not realize that in order to manage two locations, you need to have two substations. Going to shop for other camera options and throw Arlo in the trash. Please correct me if I’m wrong.
prior to the upgrade Arlo has been great. Simple to use and setup. With the upgrade they changed everything. Took away the simplistic and added unnecessary complexity.
would be nice if you could easily reach a human to discuss this with.
LS
BrentV
I have 7 cameras and two base stations.  I was always able to easily arm or disarm or geofence the two base stations separately.   The two base stations are in different locations and  I always paid for specific cameras to monitor & save data.   NOW with the system upgrade they tell me I must have another plan.   I just paid hundreds of dollars upfront and basically Arlo team wants more money for the system the worked for years to my satisfaction.    Why can't I have tow base stations assign to different locations under my one plan??    I cannot ARM or DisARM by base station anymore?? HELP.
DannyBearAgain
Unfortunately arlo is no longer paying for free lunches anymore.
That’s how they treat their loyal customers.
Tsbaughman
Here's a tip in response to Arlo's latest trick: I will be leaving Arlo after being a customer for years.
At Arlo's prompting, I switched to the new software, learning after the fact that I am now required to buy two separate accounts to protect my homes. Essentially, both homes are either on or off, there is no longer the ability to independently control 2 homes short of establishing 2 individual accounts, at twice the price. This not only exposes one of my homes to break in and theft, but also suggests Arlo has no moral fiber or basic business ethics. Adding further insult, your customer is unhelpful, lacks a basic understanding of how your products work, is unreasonably time consuming and ineffective from its foreign location. You've lost your way Arlo.
  • 11 Replies
  • 12760 Views
  • 18 Likes
