I try to keep my cams set to 100% motion sensitivity. But they keep resetting themselves to 80%. Why? Then, when I try to reset back to 100% they default back to 80%. Eventually it wil take and stay ay 100% for a while then reset themselves back 80%. What is wrong?
Easiest thing to try is a power reboot of you base... see if it fixes things
@HogRyder Are you setting it in the rules for the camera and saving it instead of the motion test that is just a test.
Note the settings need to be applied to the camera rules in each mode. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
The setting in the motion detection test is just temporary - for testing. It's not saved, so it will revert to the default.
