Trying to charge camera but says "Use factory charging system"
trying to charge camera says need correct charging connection using factoring charging system
Make sure it really is the Arlo charger which has both 5v and 9v outputs and use the Arlo cable, too. If correct, try a different charger that also supports both voltages to see if that helps.
