Hello, I’m unable to connect my VMB4000r3 base station to HomeKit. Can you please help with a token reset so I can get it connected again?
Thank you
Thank you
Hi @ShayneS,
Could you please reset my HomeKit token as well so that I can reconnect my Base Station?
Hi I cannot get my basestation to connect to homekit. can i have a toke reset please?
thanks
Thank you
Hello Shayne
i dif an init of my arlo base
could you generate a new token to connect to homekit please ?
thanks
Thank you
@ShayneS Hello! I'm also requiring a reset for my basestation's HomeKit token please. I have an Arlo Pro 2 VMB4000r3 model. Thank you!
Please disregard my previous request. Reset was completed by twitter support team. Thanks!
@ShayneS can you reset my HomeKit token as well?
@Timmy2411
Thank you
