  • 1 Reply
  • 1949 Views
moe3043
I have the original arlo camera system.  Just recently bought the arlo pro 2.  I would like to connect the arlo pro 2 base station and disconnect the original arlo.  I would also like to connect the original arlo cameras to the new arlo 2 base station.  What would be the process to complete the task? if any.  Also.  Is there a credit for the original arlo cameras?
Streak2
Master Master
You don't need to disconnect the original base unless you want to. Having two bases will allow you to position them either side of the house connecting the nearest cameras to the relevant bases. Also if you now have more than 5 cameras you will be able to split them across two accounts, one per base and still have free 7 day recording.
If you do want to remove it then in the app just remove it under settings but remove the cameras first.
Then just add the new base and sync all the cameras, old and new to it.
  • 1 Reply
  • 1950 Views
