Anyone else experience issues with a camera and subsequently little to no help after? The Arlo support is years behind SimpliSafe. I called in since there’s no email address that’s supplied for support. Was on the phone an hour and a half. Was told back on October 10th they would ship a replacement camera. Still nothing. Similar issue with SimpliSafe and had replacement within 5 days.
HI @smitty24
Do you have the case number and or RMA number. I would like to look in to this for you. Thank You
I would suggest contacting customer support and inform them of the issue with your RMA & provide the RMA #. I have attached the link here for you - Arlo Tech Support
I have escalated this issue for you. Support will be reaching out to you as soon as possible. Please keep me informed & I will be here to assist you.
