  • 26 Replies
  • 2285 Views
  • 3 Likes
  • 6 In Conversation
Ceej
One of the Arlo Pro 2 cameras in my account went offline randomly as it does every couple of months. After going through the normal process of deleting it and readding it, I was suddenly greeted with a ( ! ) icon and a message telling me I now needed to buy a subscription. That's not the case for the Pro 2 and has not been this whole time. All other cameras are online and recording for 7 days without a subscription.
I have tried deleting and readding and ensuring all rules are also deleted. Nothing has worked. From what I understand, Arlo may need to resync manually on their side.
To make matters worse, I can't even speak to live chat without a subscription any longer, so if this can't be resolved through this thread, I'm SOL. Please update the EOL policy for the Pro 2 cams if something has changed.
26 REPLIES 26
Some legacy users have gotten a trial subscription automatically, triggering that message. Don't worry, when the trial is over you revert to the free plan as before. You can check Settings, Subscriptions (or similar) to verify this.
Ceej
Well, it's been 7 days and nothing has changed. Camera remains unusable with a permanent prompt to sign up for a paid subscription. It doesn't appear that I ever was signed up for any free trial either - my account shows no plan at all and I'm not even prompted to sign up for any trial.
It certainly appears that either Arlo has quietly changed its EOL policy on Arlo Pro 2 devices without notice or this is a bug of some sort. All my other Arlo Pro 2 devices remain operational with 7-day cloud footage. It's clear to me that once the other cameras go offline due to a technical issue, that'll be it for them too.
If Arlo changed their EOL policy, it would be documented. See:
https://kb.arlo.com/000063018/End-of-Life-for-Arlo-Legacy-Cameras-and-Arlo-Services
How many total cameras do you have and which version(s)?
BrookeN
The Pro 2 cameras should still be working as expected.  Can you try logging out of the account and then logging back in? You can also try resetting one of the Pro 2 and then adding it back to the account.
Ceej
It's not. I have deleted and readded this Pro 2 camera at least 8 times at this point. Each time, when it pairs to the base station, I am presented with only 2 options - select a subscription or "maybe later". Regardless of which I select, there is no option for a free trial nor is there an option for the legacy 7-day Pro 2 subscription.
Up until this camera experienced a technical issue where it lost its connectivity to the base station, it was working fine in this account. On it, there are two base stations - the first one has 3 Pro 2 cameras and the second base station had (prior to this camera experiencing the technical issue) 4 Pro 2 cameras. If someone is going to chime in here and say that that's too many cameras for the legacy Pro 2 subscription, then please advise why this setup was working just fine up until this camera experienced a technical issue. Otherwise, please advise on what exact steps need to be taken in the app to get this camera back online.
BrookeN
Are you still seeing this same behavior?
Ceej
I sure am. The camera remains inactive with the only option being to pay for a subscription.
BrookeN
What happens when you click no when onboarding? Does it move forward or does it stay on the same screen?
Ceej
Neither - it returns to devices where it shows a red (!) icon over a greyed out BG for the camera. From there, my only option is to subscribe to a paid plan.
BrookeN
Can you please send me screenshots of what you are seeing?
Ceej
I have been trying to delete and reconnect this Arlo Pro 2 camera using different orders of operation and I always get this result no matter what. There is never an option for a free trial. The app is treating this camera like any other newer model camera. Device has now been unusable without a paid subscription for close to 2 months.
How many cameras are in the account?  Free cloud storage is limited to accounts with 5 or fewer unsubscribe cameras.  (That isn't a new limitation btw).
Ceej
There are two base stations. This is and how it has been working out for years now:
Base Station 1:
- 1 Wireless Video Doorbell (not recording clips; expected)
- 4  Pro 2 Cameras (all four working & recording clips)
- 1  Pro 4 Camera (not recording clips; expected)
Base Station 2:
- 4 Pro 2 Cameras (three of the four working & recording clips - one no longer doing either following a technical issue that brought down its connectivity)
My question to you is this, based on the claim that there are too many cameras associated with the account:
Why were all 8 Pro 2 cameras working just fine up until a few months ago? Even now, if the limit is 5, why do I still at this moment have 7 online and operational? Something isn't adding up here.
You shouldn't be getting any cloud recordings with 10 unsubscribed cameras in the account. So the mystery here is why you were getting recordings before.
Is it possible that each base is in it's own account (sharing cameras to get full access)?
Ceej
No. There is only one account - this one. Both base stations are associated with it and have been since 2018.
And I wasn't just getting 7-day cloud storage before - I still am right now for 7 Arlo Pro 2 cameras (although I suppose Arlo is now going to manually take that access away thanks to this thread).
Also, why is it that this camera is just straight up unusable? Why can't I at least have the camera record to local storage? Is this how Arlo has always been set up, where you can only record locally if you also record to the cloud?
What models are your hubs?
Ceej
One is a VMB4000r3, the other is a VMB4500r2.
Both of these support local recording, but neither support playback.  The only way to see recordings stored on these hubs is to eject the storage using the app, and then connect it to a PC and browse there.
Viewing local recordings in the app requires either a VMB4540 or VMB5000 smarthub.  There are limitations
  • recordings can only be viewed in the app (not my.arlo.com)
  • recording can only be viewed using the primary account (not shared accounts)
  • no thumbnails, so recordings need to be downloaded to your phone before you see anything
  • no ability to make manual recordings or snapshots while livestreaming
  • remote access requires router setting changes that some find difficult (and which will not work with some internet service providers).
Ceej
Well, just like I predicted in a previous comment - another camera experienced a connectivity issue following a thunderstorm that rolled through the area. Upon restoring connectivity to the base station by taking the battery out and putting it back in (like I've had to do periodically for the last 7 years), it is prompting me for a subscription. Now two of my Pro 2 cameras are unusable.
Honestly, to chalk this up to a "bug" that granted me access to more cameras than I should have had access to for all these years sounds incredibly fishy. I can tell nothing is going to be done about this either way.
Between this, the obnoxious skyrocketing of subscription fees, and the consistent random disconnecting of cameras, I will be joining the list of people ditching Arlo and installing a more reliable self-hosted solution to stop giving corpos like this an exorbitant amount of $$$ only for them to turn around and implement more anti-consumer practices like the one demonstrated in this thread.
JGKG
Same happened to me.  My feeds disappeared.  I am notified of motion and can log in to look around but no feed.  When I select feed, it attempts to sell me a plan.  In the plan it offers 60 days of cloud storage but clearly states you get 7 days without a plan.  When I tried to reach out to live support, it says I can't get support.  Verizon tried to get me going again and said I would now have to purchase a plan.  This is BS!
BrookeN
Best516
I am also having this same issue.  I purchased several Arlo Pro 2 cameras from e-bay, August of 2025.  Three of the new/used cameras have reacted just like yours, "This device is inactive -- a paid subscrition is required to activate the device".
Two other cameras paired just fine and operate correctly.  The interesting point is that they were paired at different times and were intermixed when doing so.  I am concerned about rebooting the hub and then negatively impacting my entire system.  Any updates to share?
So you have a total of 5 unsubscribed cameras in the account?  And these are all Pro 2 cameras?
Best516
Hardware 3 & 4 operate correctly. Hardware 5 & 6 are no active and state they require a subscription.  The Firmware numbers interchange with the Hardware numbers, so that must not be an issue.
  • 26 Replies
  • 2286 Views
  • 3 Likes
  • 6 In Conversation
