Squirrels moving camera. Is there a way to mount the cameras with them moving it?
New user here, so far I like the cameras but is there a way to mount it without squirrels/animals moving them or damaging them? I mounted a camera in a tree with a ghillie and magnetic mount but a squirell knocked it down. Less than 24 hours ago I remounted it using a screw in bracket and already a squirell moved it! This is aggravating! Is there any way to avoid this? Thanks!
you need 1 air rifle
Ha ha. There are far too many on my property and I'm not allowed to do that in my area.
Just use a good mount and if the arlo mount make sure the locking nut is tight... or remove it if plastic and use a regular 1/4-20 nut to tighten
Only if you got caught. 🙂
As Tom suggests, there are lots of outdoor camera mounts including those from Arlo. A quick search on Amazon can be overwhelming. They just need to use a 1/4"-20 thread which virtually all do.
Another put the camera in a bird house to hide it.
You could mount an owl or hawk statue close by.
I use plastic snake replica to keep birds away.
I used the Wasserstein (idk how to spell it lol) adjustable screw down bracket and ghillie last night after I realized the magnetic mount definitely is not enough for this situation.
Today I retightened everything and hopefully that does it and stops it from being moved.
I must have very aggressive squirells 🤬
