  • 2555 Views
JGP7229
Recently purchased Arlo solar panel for an outdoor camera. I have charged the camera to 100% plugged the panel in and without any usage the battery is draining about 3-4% a day. Any troubleshooting tips would be appreciated.
Thanks!
Is the panel showing a charge "lightning"  icon during most sun time?
Is the temp below aprox 32F ?  ( as the battery doesn't charge below freezing for safety )
Is it cloudy?
In my experience, the panel only really charges a few hours before and after high noon if sun, but did manage to keep my battery charged over long term ( not winter tho )
BTW, Angle of panel should be facing sun at high noon, aprox the angle of your latitude
JGP7229
@TomMac no its not showing the charging symbol at all, I live in Naples, FL (we don't really have a "winter") and all we get is sun this time of year, average temp this week was 90 mostly sunny, about 1 hour of rain...
I've disconnected and reconnected the camera several time to check the connection with no luck... it is receiving direct sun light but can try moving/ adjusting the angle and see how that works.
Thanks for the quick reply
ShayneS
@JGP7229
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 2555 Views
