I have an Arlo pro 2 with arlo solar panel.
The camera end of the arlo solar panel connection cable was cut and lost.
I plan to connect a similar mini usb cable to the Camera since a replacement seems unavailable.
Does anybody know which color cable connects to which pin on themicro usb.
The 5 cables in the solar panel cable are black, white, red, green, silver.
Thanks for yout help
EvrenErtay,
Have you tried contacting Customer Support about a replacement?
