Smart motion zones on solar power
Retired_Member
Not applicable
2018-08-27
07:15 PM
I’ve read many posts here and need some clarification. I have several Arlo Pro2 cameras all with motion zones, all outside, all connected to solar panels.
1) why do the motion zones not seem to work? I either get tons of videos from the entire view, or no video of motion at all. Totally inconsistent.
2) how can I have activity from a specific zone trigger another camera to record?
Thanks!
Thanks!
1) The Pro2 originally was able to use zones ONLY if on ac power... Not sure if a fw update allows them to function on battery since released.
2) To make cam A trigger cam B, make a custom mode ( add a mode )
detection on A, record on B as rules
Hi widebos,
The cameras and motion detection works best when objects move from side to side. It can be harder for the sensor to pick up forward moving or away objects. You might want to try and adjust the sensitivity and angle as best you can for the environment. Here is a good KB Article that might help. How do I optimize motion detection for my Arlo Wire-Free, Arlo Pro Wire-Free, Arlo Pro 2 Wire-Free, ...
