  • 6 Replies
  • 1960 Views
Doualaboys
Hi - I signed up to the CRV subscription, plugged in the camera and I can set the camera to record at night but as soon as I switch off my phone the camera stops recording. Any idea how you can keep the camera recording throughout the night without having my phone on?
Adam
6 REPLIES 6
The phone has no connection to whether a camera is operating. As long as the system is powered on and has Internet connectivity recordings and CVR are active. The phone or computer is just an interface to see what's happening.
How do you know the camera stops working? Test to see if any recordings are made with the phone off. A screenshot of the CVR timeline might be useful.
Doualaboys
Thanks for the reply. I don't see any option to record Screenshot 2020-02-06 at 20.35.51.pngScreenshot 2020-02-06 at 20.36.53 1.png
Doualaboys
so when I hit record, either from the app on my phone or from the laptop, it works fine but as soon as I leave the app it just stops. I get to see the recording in my library but it's a short recording.
If I leave the app open on my phone or on the laptop then it keeps recording... am I missing something?
CVR should always record. Your timeline indicates that it isn't. For motion recording, what mode is selected in the Mode tab? Try Armed to be sure.
I think you should contact support about the CVR issue - use the link at the bottom here.
Doualaboys
Thanks - for some reason I was unable to log in so hence the delayed response. I will contact customer service.
Adam
Doualaboys
oh and yes it was set to armed. I tried over and over again  - the only way to do continuous recording was to keep my iphone / laptop open. As soon as I close the app it stops recording.
  • 6 Replies
  • 1961 Views
