Signal Strength shows "Poor" all the time
Hi all,
The base station is in the living room and one camera is mounted on the living room wall..
There is no blocking stuff between them.
There is an antenna to show the signal strength, but there is another signal strength page.
When I go through the camera's setting, Device Settings, Device Utilities, and Camera Positioning, there is the "Signal Strength" page and the status bar always shows "Poor" even though it works good.
What does this another Signal Strength page mean?
I believe that the page that always shows poor signal strength has a bug. Suggest you ignore it.
Use the WiFi indicators for each camera on the Devices tab.
