24/7 CVR Question with Motion
Hi If i put the a 24/CVR plan where i will have one camera recording 24hrs, is there is function when browsing back through the footage where it highlights or tags the motion, instead of me watching or trying to sort thru all the footage if someone was around, that would be great if someone can provide me with this info.
Any 'triggered event" that puts a file into the library will show up in the CVR time line as a colored bar ( above the regular time time )...so your answer is yes, it is tagged
Thanks I see it , although it kinda sucks you cannot CVR from the cloud those sections of motion after payinh all that money to your own device. Another question if you have a CVR Plan is it Just for cloud or can it be for location storage too? Thanks
Local storage via USB to station
Cloud only. If you want a local copy, you have to view the timeline and use screen capture software.
