  • 2 Replies
  • 1550 Views
GrandBuddy
Should we just do a new setup? 2 of our 5 cameras were deleted. How do we reactivate them.
I'm worried about all the comments that we might we require a subscription!!
Any camera from the Pro 2 or older needs no subscription for the free 5 camera, 7 day plan. Newer cameras do need a sub.
You should just be able to sync the cameras back to the base normally. Even if you do a full system reset, there's no difference in the plan you had before.
greyowl10
I have 7 cams on 2 units & have had one go off-line occasionally.   Just had to hold it close to the case & push the sync button on the base & cam & wait for the solid green lights.   If the cam is actually gone off your page you probably just need to hit "add a cam" & do the same.   The cam will need a power source  (battery or plug)   Just my experience tho.
  • 2 Replies
  • 1551 Views
