Should I Get Another Base Station?
I have two homes that are next door to each other. The Arlo Pro 2 base station works fine and I have great connectivity from the either camera. My question is if I add more cameras, should I buy another base station? If I were to get another base station would it be able to show all the cameras under one account? In total I plan to have maybe 5 cameras total. The reason I would get another base station is for the e911 and the siren.
The second base is a great idea. Ther number of bases doesn't matter, just the total number of cameras.
...and yes, they will show up on the same account as long as you set the new cameras and base station up under that same account.
