  • 7 Replies
  • 1310 Views
sdeban
Does anyone know which is high sensitivity on the slider settings? High sensitivity to me means triggered with less motion, yet high shows a running person icon. Seems backwards. Should I go by the number, higher being more sensitive, or the icons, higher being less sensitive? Arlo needs to change this so that it makes sense because it's completely ambiguous.
(I can't insert a photo of the slider because the upload box goes off the edge of my screen so I can't click the button.)
7 REPLIES 7
sdeban
sdeban
higher percent is more sensitive
DUPE question, previously answered
second DUPE question, previously answered
cameraz
Can you provide a link to that "dupe" question so those of us who don't know where to find it are able to? Seems like the helpful thing to do.
The same question was posted in 3 different areas here. It may be answered in the Pro 2 area but I'm not sure.
Answer - higher percentage/number is more sensitive.
  • 7 Replies
  • 1311 Views
