Running two Arlo bases at the same time?
  • 1 Reply
  • 8186 Views
  • 3 Likes
Mountainspring
I have been using daily the regular Arlo model VMS3230 with 4 cameras and would like to buy and run at the same time the VCS 3000 Arlo pro 2...
Would it be technically possible to run both bases/systems at the same Time???? Thanks
Not quite sure what you're asking. Yes, you can run multiple bases on the same account with no problem. The limitation for the free plan is a total of 5 cameras per account. If you'll go over 5 cameras with the new system, you can use a second account with a second email address to set up the new system. Then use Settings, Grant Access from the second account to the first so all cameras will be seen with one login. Each system will have to be run separately when using two accounts - you can't merge them.
  • 1 Reply
  • 8187 Views
  • 3 Likes
