Reset Pro 2 battery then lights flash amber and blue. Infra-red lights stay on but doesn't connect.
Hi all,
I need help please.
For some reason, when I reset my Arlo Pro 2 camera (take the battery out and reinstall it), the infra-red lights come on and then the blue and amber lights flash for a minute. The infra-red lights stay on and doesn't connect.
Please help!
That does not reset the camera. It just reboots the thing.
A Pro 2 reset, putting it back to its factory state, happens when you press the synch button, and keep pressing it until the LED shows a quick sequence of flashes. ~20 seconds should do it.
You can then add the camera back to your system.
Just another user
Believe that is the reset for the GO ?
for Pro/pro2, no real reset except pulling battery and remove device
- First of all, open the Arlo app and log in to your account.
- Go to the Settings and click on My Devices option.
- Now, choose your camera that which you wish to reset.
- After that, remove the device and confirm your action.
- Then, your camera will reset to default settings.
I tested it here before posting my message.
A long press certainly removed the camera and reset the settings.
Just another user
