Is it possible to have one camera armed continuously while on geofencing?
  • 1 Reply
  • 1052 Views
tambalamba
Can anyone tell me if it's possible to have one camera armed continuously while using geofencing? We have four cameras set up on a schedule and are using geofencing to activate when we leave the house. Ideally I would like the camera at the front door to be picking up motion even while we are at home. I would prefer to not have to purchase an Arlo or Ring doorbell if possible.
michaelkenward
Sensei Sensei
Sensei
Create a Home mode. Set that to make the front door camera do whatever you want it to do when you are at home.
Then, when you set up Geofencing, tell it to use Home mode when your are, er, at Home.
How does Arlo Geofencing work and how do I set it up?
You can also set geofencing to switch when you are at home to whatever Schedule you have set up.
How do I configure and use the Schedule option?
It may be that you already have a mode that you can activate when you are away.
Just another user
  • 1 Reply
  • 1053 Views
