Replacement USB connector for the battery cover? .Water got into USB connector and corroded.
Is there a replacement USB connector for the battery cover? The ribbon cable and connector inside the battery cover... Water got into the USB connector and corroded the contacts.
Hi Davidkevwhite37,
I would suggest to contact the Support Team to see if they can help you with that. You will find several options for contacting support in the provided link.
