Charging Fault error on Arlo Pro 2. Tried replacing battery. Plugged into solar charger.
I keep getting a charging fault on one of my 4 cameras. Three of the cameras have solar chargers, but no error on the other 2. I have replaced the battery with a fully charged one & plugged it back into the solar charger 1 week ago. Now I have the error again. Is it the camera or the charger? I have a warranty on both. I am at work now & don't have the paperwork with me, it is at home. I was hoping you could give me some guidance.
Hi morg1,
If you're experiencing the issue when you removed the battery and plugging it into the Solar Panel, I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
