My house was stuck by lighting in June 2020 and damaged my VMB4000 Base. I purchased VMB4500 to replace it. After connecting Ethernet and then applying power to the base, in that order, the LED began as a solid amber, then the LED goes blue for a while, and then the LED settles at an amber fast flash rate and the state has not changed. As I type this, the LED is flashing amber. I called tech support, they assisted me in determining the base was bad. So, they sent another one and I received it today. I am having the exact same symptoms as the first VMB4500. I would think and hope the replacement of the base station would be a simple replacement, but no luck. Any thoughts from anyone? Thank you!
Don't know for sure but maybe it's a router issue. You could try a factory reset on the router but it may be easiest to try connecting somplace else, if possible during these days.
