Could we get more details about what bugs were fixed with this update please?
Is anyone else having issues with this update? The battery on 3 of 4 of my cameras so far dropped significantly, with one now that won't reconnect.
My cameras seem to be draining very quickly recently. Not sure what's going on.
After the firmware update the sensitivity of the cameras appear to be degraded. We had a bear walk across without being recorded.
PROBEDROID,
This release addressed only very minor issues that would not have impacted most users. I do not have more granular release notes available.
JamesC,
I appreciate your response. I ask because I am still suffering from a broken Schedule, IR's on while no motion detected, degraded picture quality with occasional pixelation and ghosting on all cameras and have also seen the bug where the cameras will continue to record for a full 5 minutes even though motion has stopped. When I purchased the system in February, everything was working perfectly. Then the May update broke these things and the June update that was supposed to fix the May update didn't fix anything. I was hoping that this update would resolve the issues, but the issues remain. Could you reach out to Engineering and provide us with an update as to when these issues will be corrected please?
I think I speak for everyone in the community when I request more communication and transparency from Netgear about the issues happening with this system. It is unfortunate and disappointing that a perfectly functioning system was broken with a bad firmware update. I think the community would rest a little easier if these issues were acknowledged and we could have confidence that they are being worked on. Thank you!
I completely understand your frustration. I'm sorry to say that the only fix I've been able to come up with is to plug the cameras in permanently to combat the battery drain. I know this isn't practical or feasable for eveyone. Also, I would avoid setting any custom modes or schedules on the system at the moment. I have mine set to the default Armed mode and the cameras are detecting motion the way they should. I wish I could offer better solutions to help, but that's all I can provide for now.
What mode is selected?
Glad the cameras are still under warranty but disappointing this happened in correlation with an update and I have to pay shipping for the return
So the camera that I charged back to 100% has stayed at 100% power - however still no motion detection. Can do Live video. It is the standard armed - no special mode set up.
My other camera overnight went from ~50-60% down to 25% - which is the same battery % my other camera auto drained down to.
Very weird that both cameras have now drained or showing drained to exactly 25% overnight - also motion detection stopped working on both at the same time
Baileym1,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
