Push notifications suddenly not working (Android)
Audio on phone is all the way up. I also logged out of the app and then relogged in. Anybody know what's going on?
DanNM,
Check your notification tone by logging in to your Arlo mobile app and navigating to Settings > Notifications > Notification Tone.
I have tried disabling and re-enabling the notifications in system settings as well as the app, cleared the app cache, force stopped the app, and rebooted the phone with no luck so far.
eyestothesky,
Have you tried changing the alert tone within notification settings?
mine was not working either on Pixel 2, I added permisions for storage, location and microphone, and started working, not sure which one fixed, but do not want to touch now, as getting alerts again
Had the same issue here with several cell phones.
here's my solution:
Go to the Arlo website and log in to your Arlo account or the master account
When the cameras are shared, de-select all cameras for that account and press save.
Enable the cameras again and click save.
PS: We have 1 major family account which is the master. 3 familiy members are part of the "Grant access" group. We noticed that 1 family member didn't get the notifications on his cell-phone, but when he logged in with the other account notifications did come in (so not an app or cell-phone issue).
ok, had issue on other phone, the permisions change did not fix
we also fixed by the above fix recomendation
settings\guest acess\{users profile}
then setting "Allow Access Rights" to off, then save, then to on, then save
working again, thanks FVuitW
I am trying to turn off the Arlo smart feature as my puch alerts are acting crazy however when I try to toggle off all the slides a message comes up saying I have to have one slide activated??
However I think it’s possibly fixed by dragging the cameras in the Arlo Smart menu in settings from the active section to the inactive section .....I think this turns off the smart functionality and makes them activate/notify on ANYTHING - can anyone clarify this is what being in the inactive section means?
(note when they were in the active area of Smart I had all options for detection on so should picked up anything anyway!).
Ok, so I have moved all cameras in Arlo Smart to the inactive section and all notifications are working perfectly now....what a day I have had trying to sort this out
After testing this this morning it seems now to be notifying me on every motion detection......yipee!
Now, don't break it please!!!!
I have the same problem since my recent Android upgrade on my S9 Plus. I've done everything imaginable to fix. Works fine on my wife's Iphone 8+. I think the android arlo app is the culprit. No one seems to want to own the problem.
My S9+ problems began when my Android OS was updated. Arlo was working before. Works fine on my wife's iphone 8
You would think Arlo would be able to fix this problem???
Same issue here, with a Samsung S7. After the update the following issues have shown up:
1. Alerts no longer trigger notifications to show up on the phone until you open the Arlo app or get another notification from a different app.
2. The custom notification sounds no longer work and it uses the default phone notification sound.
3. It also seems that the notification sound repeats 3 to 4 times for each notification when they do finally come through.
4. When making a phone call the Arlo app crashes.
My Arlo app did an update last week, and the notification to switched to the phones default instead of the tone I set for Arlo. Now I can't get any alerts.
"Alerts no longer trigger notifications to show up on the phone until you open the Arlo app or get another notification from a different app.
4. When making a phone call the Arlo app crashes. " Anyone?!
@Jsabbage wrote:
Same exact issue here.
Same here.
Sometimes I have a big delay on the puch message. Today it was 20 minutes from motion until the push message came.. It is far too late to be able to respond to whether someone should be outside.
The delay may vary from a few seconds to actually not at all. I have a very fast broadband (Telenor advertises with the world's fastest
). So it should really go fast to get puch and email. Puch and email follow each other on time.
Is there anyone who experiences the same?
---Svein Olsen, Oslo, Norway---
(...and I hope Google translater do it well...!)
Is this camera on Arlo Smart?
No. I expect that when the buttons show green - is slid to the right - all the movement is reported about.
hello,
same here.
with arlo smart active on 5 cameras, push notification does not arrive at all.
email notification arrive minutes after the motion detection. sometimes email notification arrive 3 or 4 hours after the motion detection!
now I've disabled arlo smart (on all cameras) and tested all the cameras: email notification arrive within minutes, push notification does not arrive or, maybe, 1 of 10.
p.s.: I'm sorry for my bad english.
Android or iOS? iOS update today might of helped, if Android uninstall the app and download an older apk and turn off auto updates see if it’s any better or now.
