Push Notifications When Phone Is Set On Silent
  • 2 Replies
  • 5613 Views
  • 2 Likes
mattymoe
I have a Google pixel phone (Android) that I prefer to leave on silent. Only the phones alarm makes a noise when set. Is there a way to set up my phone or Arlo 2 system to also receive the Arlo 2 push notifications with noise even if my phone is set on silent?
pilotchip
  1. Go to Android settings
  2. Apps & Notifications
  3. Arlo
  4. Notifications
  5. Select "Override Do Not Disturb"
To make this happen, your phone probably has to already be on Do Not Disturb, not just manually set on silent or vibrate. In your DND settings, you can specify Alarm Only, etc. Then the above steps will allow Arlo to override that and work as desired. I have DND set to go on every night at 11pm and off at 11am and to only allow Alarms, and texts/calls from starred contacts (such as family & work). You can also set DND to return the phone's ringer to default volume when you turn off your alarm in the morning.
pilotchip
  3. Arlo
  4. Notifications
mattymoe
Thank you so much...this is the perfect solution. Much appreciated!
  • 2 Replies
  • 5613 Views
  • 2 Likes
