  • 1 Reply
  • 2850 Views
TaylorSystems
I have seen this in other parts of the forum and nobody in Arlo Support seems to have bothered to address or comment on it.
The issue is that anyone who has been granted access to view your cameras are ALSO receiving PUSH Notifications (that are NOT Desired). This annoys everyone and makes relying on Push Notifications unrealistic if they have to be turned off because of udesired notifications going to everyone except the person desired.
When Granting Access to cameras... it should be possible to SEPARATELY Enable or Disable 'Notifications'... whether they are 'Push' or 'email'.
One might consider this a 'Feature Request', but if it is causing problems then I would suggest that it be considered a problem.
Greater granular control over Notifications is needed.  What is the status?
Pushes are for all...either on or off.
Emails can be be on a users basis
you may be better served posting here : https://community.arlo.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange
  • 1 Reply
  • 2850 Views
