Hi,
1 of 4 camera went offline after powerless for 250 days.
Now when i put in charge cable it just blinks blue/orange for 30s. then stops for a while then starts blinking again.
Factory reset does not work either 😕
Managed to delete the camera from my account.
Is its possible to fix or just throw away?
no warranty left..
Nobody? 🤷🏻♂️
Honestly, it would be a throw away.
the rapid blue orange flashing suggest it was trying to perform a firmware update that failed.
with a dead battery the camera charger locks out for safety.
shame you removed it from the account since it is now unlikely to be imported again because of the current status.
You should expect a days delay delay for comments.
Try this procedure to see if it helps:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
