Hi,
During my move, the plastic yellow ethernet port was somehow lost from the back of my Arlo Base Station. Has anyone found a compatiable port that would work? I would raher not spend $80 on a new base station for a .10 peice of plastic.
Thanks,
Is i just the shell that's lost or the contacts, too? If just te shell, you may be able to find another to fill the hole. If it's the whole thing, you'd have to disassemble the base and solder in a new one of similar construction.
