  • 1 Reply
  • 2011 Views
ellina
Are there any limitations using the original Arlo base with Arlo Pro 2 cameras? Is it slower, can it handle the higher resolution, etc. Maybe a better way to put it is - Is there any reason to upgrade to the Arlo Pro 2 base from the original base?
All Arlo wireless cameras work with all bases. The difference is newer hardware and the built-in siren.
  • 1 Reply
  • 2012 Views
