I have 2 Arlo pr 2 cameras that had the lens's destroyed by a woodpecker. I cant find any help on a repair center, or Arlo tech support for options other than a new camera purchase (which I did x2).
Isit possible to use my damaged cameras without the lens over the IR?
Being a techie kind of guy, Is there a material I can buy to change out myself to repair or at least repair to use indoors (out of the weather)
I have seen some other post about woodpecker damage. Unfortunately Arlo does not repair cams or even provide parts. I can't comment on the lens question though. Mabey someone will chime in about that.
Thank you, Yes I'm hoping for someone that would know if there is a lens material i can find to create and install myself. I'm not happy with Arlo that I have 2 cameras that do work but the lens is damaged creating 2 bricks, not to mention their horrible tech support.
