My arlo pro 2 camera stop recording to cloud. I still receive alert but just no recording. I don't have subscription but it is supposed to record and keep for 7 days. I didn't change any setting and I reboot several times, remove cameras battery. Reboot router etc and still no luck. I can manually recording and it show up in the cloud though.
Message 1 of 3
1,216
Spoke to support and the issue resolved. Remove the camera and resync again solved the problem.
Message 3 of 3
1,198
Use the Contact Support link at the bottom here to raise the issue. There have been a number of recent similar complaints.
Message 2 of 3
1,201
Message 3 of 3
1,199
