Pro 2 camera won’t record?
First ARM all you cameras and verify the 'armed' icon is black ( turned on ) ( either running man or ball with lines )
If correct, try rebooting the base ( power off then on , wait 2 mins to come back , test )
And/ Or pull battery then replace to reset camera
If still NG, use remove device and then bring back as new ( this will rebuild default settings in base )
reset the sense level in mode to about 90%
If still NG, it may be the camera is bad... but go thru steps and report back
