Possible for someone have access to Base Station if they don't have Arlo login and password?
  • 4 Replies
  • 2456 Views
cad0914
Is it possible for someone who doesn’t have an arlo login and password but does have access to network/base stations/router to access cameras or recordings somehow?
Streak2
Master Master
No, unless you are recording to external storage like a USB stick or SD card which can the be attached to a computer and viewed.
The recordings are stored on the cloud not on your network (unless USB/SD as mentioned above) likewise to view the cameras you need a login and password either for the app or for the web interface.
Streak2
Master Master
cad0914
Thanks for the reply. There is external storage but this also cannot be accessed unless removed from base and plugged into PC, right?
Streak2
Master Master
See this KB which does a better job than I can
https://kb.arlo.com/1146850/How-do-I-view-videos-saved-on-a-local-storage-USB-device
cad0914
Got it, was just making sure there weren’t any other less obvious ways that maybe I wasn’t aware of. Thanks again for your help!
  • 4 Replies
  • 2457 Views
